The brake /left and right lens do not go on the tubes.
They go on the black housing and then the plastic is lightly melted around the lens keeping them in place.
That is why the light tubes are sold all the same.
The texture inside the black housing is correct.
IMO and I repeat IMO. The gauge metal housing was bead blasted beyond requirement. It almost looks painted grey.
Too much of the metal surface finish was removed and thus you lost the original look
of the metal that was once poured. In one of your pictures , why is your OIL gauge already showing a reading?
The 2 rubber vibration grommets on the speedo should have been replaced as one already looks split.
The small round foam seals are available for the black plastic housing
light tube area.Contact Mr.Heaterbox 613-532-2587
Jules
