Thanks guys. It sure has been fun to work on a car that hasn't been butchered. After much discussion around the upholstery bench we decided to build one of our 511 short blocks into a stock appearing 383 with stealth heads. I have a Dana 60 housing with some ends that will go in it at some point as well. It should be a fun car with the column shift. We need to use up as much of our parts stash as possible. Good times.
