No alternators.....the battery going below 12 volts during the run is my reason at the present for running the 16 volt battery.Running alcohol in both the dragsters and the faster the engine turns the better they crank on alcohol.But if someone has a better idea,better choice in batteries I'm all for it.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
