Thanks guys
The oil pump is good but would like to change the spring to get alittle bit better oil pressure. The oil pan is a 7qt home made pan and yes with the filter it makes it a 8qt system. The pan needs some work. I'll make sure to get a good oil filter. The heat cross over on the w-2 heads is a opening in the middle on the intake port side that's about 1 1/2- 2" deep that doesn't go anywhere. We had a decent amount of oil laying up in them. Could be the falt of the intake gaskets and being that they were some home made deals from who knows when. Who ever made them must not of made them right. I think the brad penn oil isn't bad compared to alot of other stuff. Last time I knew they were selling it for 6 bucks a quart.
