Quote: I was looking at our oil pump and seen that it was a hv pump. I don't know if the 7 qt pan is enough for such a pump? We did have alittle to much oil get up top into the heat cross over in the w-2 heads though.
7qt pan will work fine with a HV pump. I run 7 qts in an 8qt pan with no problems. FYI, Most of us run more pressure than most oil manufacturers recommend ( 10 psi for every 1000 rpm, starting at around 10 - 15 psi at idle ). I'm about 20 psi over that accross the board. Probably cost me some HP, but it's nice to have a safety margin in case you have a valve train failure, etc. Also why I always run a HV pump.
