Ok here is a pic. and before I start welding I just want to get opinions on the install so far.
The chassis is on stands at the Rake I want/ Ride height, the rear housing is in the proper location and also at ride height.
My ladder bars at the center hole have 1* nose down
Each hole seems to be 2* difference maybe 2.5*
Next lower hole they are at 3* and the bottom hole they are at 5* maybe 5.5*
Do you see any problem or error in what I have so far?
Looks good... burn it in... looks like you have plenty
of adjustment
EDIT
One other thing to help you... since your running a
diagonal link and I'm guessing this might be a street
car also... weld a gusset on the rear end down to
the lower hole area on the ladder bar bracket(where
the diagonal link attaches)... that really helps the
bracket from cracking from the side loading on the street
![](/ubbthreads/images/graemlins/wave.gif)
