Quote: Thank you Mr. P, Since you did not correct me should I accept the axle pinion angle of 2*-4* nose down is correct?
I dont believe my front crossmember is too high but I will of course double check and measure a few more times. I will adjust what I need to make the lower bar 2* nose down on the lowest hole.
I will follow up with a few pics
Thank you. henry
1* to a max of 2* down for ladder bars(you get very little roll up on the pinion with bars)
