Re: Ladder bars on A body
[Re: dartman366]
#1352750
12/31/12 12:47 AM
12/31/12 12:47 AM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
is the rear axel set at the ride height that you want?? if not then thats the first thing you need to set, then set the ladder bars level to the car and then use the center hole of the front bracket with the holes in a vertical position, you will need to attach the crossmember at that point,,my first attempt at this was with a round tube crossmember and it actually hung below the subframe connector, worked that way for years untill I went to a dana and from 32" bars to 36" [Email]S@W's[/Email] and lowered the car somewhat,I then went to a 2X3 front crossmember with 5 adjusting holes.
Yes the axle is set at ride height, and the bar is leveled to the car.....
