Took it out and ran it good for the first time sense problems. Feels like it may have a little bit of a hick up when at about 45 MPH, but nothing I'm unhappy about. Will pretty much spin tires through all 3 gears. So very happy with that. As of right now only issue I'm left with is the rough idle. Timing still bounces a little and engine still shakes at idle. Have to have idle set at 1000 rpm so that when I put it in gear the RPM won't drop to far and die at stop signs.
