Where (in the car) did you guys run you're main wire to the front? I've thought about running it up the drivers side along the door sill and through the firewall. This way it's not exposed under the car.
Thats what I did, ran it through the interior. I used a grommet through the firewall that was there (think its for factory clutch linkage?) to keep it isolated. No issues
