This is a drawing of my cars plot. The center of gravity is found from scaling the car. the height of the center of gravity is one of the points to determine the "anti squat" line. The height of the C/G is projected over the C/L of the front axle.
General rules...
Any intersection points above the anti squat line will make the axle housing separate from the chassis.
Any intersection points below this line will cause the axle to be driven up into the chassis.
Any intersection points behind the actual C/G will work well with lower power/TQ combos, and vice versa.
"use it 'till it breaks, replace as needed"
