Itersecting point too high. Raise the rear of the bottom bar and lower the front of the of the bottom bar just a bit. Then lower the front of the upper bar. Make a invisible line through those two bars and make where they intersect real close to the bottom of the front bumper. Thats how I would start anyway.
Brian
Ok im goin to try that. im just not getting the hook I think I should get
Have you ever had your car on scales... you should
so you can get a idea where the at least mid weight
of the car is... we can tell you all sorts of points
but you would end up working your but off... if you
want a guess I would put it at about where your
trans mount is... so do the cardboard thing to see
what the angles would be
Is it spinning or what
