useing you watch dial as reference. Here is the question , with a 116" whl base. if the angle of the top link rear hole is say @11 and the front hole @ 2 , then with the bottom link rear hole @ say 7 and the front hole @4. now useing these angles how do you think this setting would react. and just discuss how you set your top and bottom links and how the different setting would react to different adjustment. thanks [/quote
How are you getting 2 on the front top bar and front
bottom at 4... you messed up some numbers
well im saying that if you look at my bars back of the car to front. now look at the top bar the read rod end hole would be mounted at 11oclock the front at2 oclock draw a line connecting those point , does that make sense. and the same with the bottom link rear rod end hole at 7 the front of the bottom link rod end hole at 4oclock draw a line . these two angles
First thing when you talk 4 link... you have you
hole locations and then you have the IC location so
if you say IC thats the intersection of the 2 bars
Mr p I have a Baseline suspension article. its at baselineSuspensions.com.....Launching a Drag Car. If you look this up you will see a diagram and my suspension is set up just like this . I just changed to this setting and I have not tried it. I just don't want to get to the track and be all out.
