I'll take a stab at it with right at 600 with the Dom. Good luck! Take some video if you can!
Randy
Good point... I'll take my video camera..... if the
1050 proves to make good power I'll pull the intake
and machine it to fit the dom but I'm hoping the 850
will be close to right... that way it would be a bit
friendly on MPG on the street.. but I've machined
intakes before to fit a dom....... Randy did you think
that their dyno was a fair dyno when it came to the numbers
(I forget what yours made on it).... I dont need
some BS numbers... just a fair number that I can
figure if my chassis is working right
Mike, I think the numbers Shawn came up with were probably pretty close. I haven't had my car out yet to see what it REALLY makes but hope to soon. My 540 made 830 on their dyno with limited tuning. When Shawn, Sean, and I were planning the build and came up with the parts combo, Shawn said that he had built similar combos when he worked for Chuck and that they made about the same number that mine did. We'll see..... Good luck again! Oh, what are you using for fuel?
Randy
