Don't waste your time or money on a 9000 series. Get a 6000 series. End of discussion. Period.
Also, since you're putting on one a 318, get one for a small block. You will be happier with it than trying to make a big block carb work. This will limit you to 73-74 340/360 carbs but you will have much better luck with one of those. Get a rebuild kit, they are not tough to rebuild. They can be tricky to tune however.
Some of the early 9000 series carbs from around 1974 are also good carbs and were used on 440 cars/trucks. I used a tweaked 9013 or 9014 850cfm TQ on my built 340 motor.
If you could find a 9800 series electric choke aftermarket TQ carb that would be the best carb for your 318 imho but they are hard to find. They were jetted fairly lean so tuning it would be pretty easy for your 318.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
