I've gotten curious about Thermoquads and want to give one a try. I'm trying to find one that will run well on my engine (318 67 closed-chamber w Summit 6900) without any parts changing. I'd like to see if I get better throttle response and easier cruise tuning/economy than fidgeting with my AVS.
I've tried researching for my application, I'm a bit lost even with Vaanth's guide. With all of the different ones available on Fleabay and the like I'm really not sure what would be both a cheap & appropriate option for me. I know different years introduced different electronic emissions things that I probably don't want, but some earlier year carbs miss out on improvements done sometime in the 70s. Apparently some but not all later-70s carbs have a limiter or cap on the metering tree adjuster which kind of defeats one of my goals, etc.
What should I be setting my sights on?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
