i help with a unlimited 8.5 car.
the tire size is 9 inches wide, it goes low 1.2x sixty foot. it runs low 5's in 1/8.
it take a certain mind set to do that. in the time after the burn out, the driver needs to check all gauges, turn on nitrous, open bottle , find the best part of the track as possible , pre stage bump im... all while worrying about how the car is going to react... will it hook and go, will it blow the tires off? will it stand straight up?, all of which he has to deal with differently... so if anything having your buddy put you in the beams is just a little comforting. having him put you in the best groove is that much more comforting. and knowing he is making sure your perfectly straight, so you dont mow the tree if it wheels stands helps too. its a lot mental
