Great post, and good info
Wish Id read it several years ago.
Window switch or controller is a nice add on is all I can add vs a micro switch (they can stick).
But if you have an older 6al, the 3 stage retard is a nice unit.
Some of us are hard headed (stupid) and learn the hard way.
Never rush the adjustments and make sure all is working properly.
Nitrous is a great power adder after you learn the ins and outs.
This was all avoidable, 100% human error on my part. But only took some paint work, a tear down and alot of parts magged and six boosters in the carbs. And a new set of muffs, just the guts were tossed out.
Not an issues since....because I no longer rush and inspect the system prior to every use. And I only spary on the streets 1/10 as much as I used to.
http://s1117.photobucket.com/albums/k589...rent=RTWEB1.mp4
