I will double check the air in the lines. I know I bled the system twice but I remember after I got done checking everything that the screw on the bottom of the proportioning valve was just a hair loose and I tightened it up. That could be causing the leak and the soft brake pedal... I will be bleeding the system tonight to double check.
When you bleed the brakes, start with the furthest wheel from the master cylinder, otherwise you will be leaving air in the system.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
