Just to be clear.... ONLY the upper control arms from an A body will fit an A BODY. What Andy F meant was the later A BODY upper conrol arms. All 73 and later disc knuckles/spindles used a larger upper ball joint, and the older upper conrol arms with 9" drum brakes used a smaller ball joint. Jeff
