I mounted the RetroSound 6 X 9 speakers in the rear shelf. The mounting holes lined up. I used no. 10 screws (with the heads cut off) and used two nuts to lock the remaining screw threaded studs protruding down to mount the left speaker. For the right speaker I just used no. 14 screws from the bottom. See pics in attached thread. Ron
