It's looking lie i might need a re-curve in the distributer but for now its set at 8 degrees initial plus 35 degrees mechanical for a total timing of 43 degrees wich sounds pretty high but running higher octane fuel should make up for some of it correct? since 91 octane burns slower then 87 i should be safe to run at 42 to 43 degrees total timing on higher octane fuel.
