One thing to consider, esp if you think you might be trying different cams is the SM beck style puck lifters.
I have used them on 4 of my last strokers, currently doing a build and dont seem too impressed by comps "lightweight" edm lifters at over 100 grams.
The SM solides were right at 73 grams per and really its easy to work around the lifters needs with the increased spring pressure needed.
Consider about $450 more the comps edm-s would not be the only added cost, better pushrods,springs,ect add to the cost but here again I feel used right they are bulletproof.
Ive one set going on 4 hard years and I think 4 cams and show as new other then normal lifter body wear.
And 73 grams is pretty light and I never worry about the valvetrain.
