But if this tranny was being placed into a 69 or 70 Mopar, wouldn't the three pin NSS be used instead of the one prong??
If you are putting it into the later body style then yes the three prong plug needs to be used. If you are useing an older tranny this would need to be changed anyway or you would not have back up lights. Pretty much renders the rest of my posts moot huh? At least you learned what a rooster comb is. I learned a little too. That's why I come here. I am always running off and doing things that can't be done.
I have mechanical Aptitude. I can screw up anything.
