Quote: I want to say I have heard of running dry ice with an antifreeze mixture in the innercooler.
we tried the dry ice trick on an all motor car i work on. makes ALOT of vapor and didn't really seem to work any better than normal ice. However, we don't like the water super cold because it will crack the paper thin cylinder heads
The dry ice/antifreeze mix goes in the intercooler to cool the intake piping. There is none in the engine.
A lot of people who run air/water don't run radiators and use the intercooler water tank to cool the engine.
