I haven't tried to fix anything, and I won’t. You can’t believe how out of control this can be. This isn’t like a power skid where the back end comes around and you counter steer. That I am quite good at as I live in Minnesota and do that in the snow all the time. This is every which way and even when you let off its not clear where you are going. If someone had some tires that might match up I would be willing to try that. But otherwise, I wouldn’t let some one have these as they are killers right now, and I am going low 7’s in the 1/8th at 95-96 mph.
