Quote: Did painting the back of the hood also mean painting the cowl area under the vents black sorta of like when they black out behind the grilles.
Larry
That should be the case, although I believe dark colors did not get the cowl blackout....I' have to check, but I believe the factory engineering docs do indicate which colors did (didn't) require the blackout.
The cowl blackout was for all cars, regardless of hood type or hood paint... except for colors listed on the attached drawing.
