Thanks everyone, all you guys are definately some great incentive. I have no motor or trans yet, still trying to figure out the combination that I want to run. It will definately be a single turbo blowthrough small block on E-85. The goal is to keep the car very sedate looking, with alot of trick fabrication. This is a project with my son, and he has been there every time have worked on it, which is not the most efficient but that is the only way he's going to learn. I will keep the photos coming as I make progress on the cage, interior, and rear suspension. Again Thanks for the kind words. Jody
