Quote: I wouldn't have thought a cutter on a mere 6" shaft would bend like that, but I can believe it could happen.
Typically it's the sanding roll mandrel that'll bend. The rolls aren't exactly balanced well and if it comes out of the port at speed that puppy will go at a 90 degree angle right away. And if your face is anywhere near the port at the time...
