I used to use the Craftsman die grinder - back then it was the only reasonably priced one out there. Problem was it got too hot to handle after short use. Also, get one with variable speed ... you don't want to be doing everything at 25,000 rpm !! For minimal use maybe check out Harbor Freight !!
