Quote: Brian the only down side to mounting the scoop to the carb/car is you may have to have 2 people to take the hood off. If you always have someone go racing or to help work on the car then go for it
I rarely have someone that can assist with the hood. Maybe I could look at one that has some taper from the top to bottom that would make it easier to remove solo. Should be lighter without the scoop also (making one person removal easier)??
