Quote: Paint your hood top and bottom and the scoop white. That will cool the air charge that comes into the carb. That will make more HP than an aero scoop.
WTH does the paint color have to do with the air going into the carb?
I would think little to none. I guess the air temp from a white or liight colored hood vs a flat black hood would be no more than a few degrees?? It's not pulling air off the hood.
