Turbo BSFC numbers on a dyno may often be better than NA... except that is at high load. At real "road HP" - off boost - the lower compression ratio on a turbo hurts.
Agree as several have posted, a smaller engine with turbo may do better in real world driving compared to a larger NA engine. Comparing same sized engines, the turbo would likley be worse than NA though.
