Key point - equally-spec'd (which I will take to mean same max torque and HP).
To gain MPG I think you'd need to go to a smalelr engine boosted to the same overall output, so that when not in boost you benefit from the smaller engine.
There might be some engine combinations that might become more efficient at certain RPM when boosted, but as a rule I'd say boosting an engine will drop MPG.
