Quote: Doc, I like you and all, but you are in the minority on this one. You are the only one that I have ever heard refer to gears this way. Short, low, digger, deep gears = 3.91 and numerically higher. Tall, long, highway, freeway gears = 2.76, 2.93 etc.
Rear axles are named the same way as transmissions. In transmissions, the "Low" gears are the higher numbers 3.09, 2.66, 2.74, 2.45, etc. "High" gears are the lower #'s, as in 1.0, .70, .67, etc.
Same thing for the rear axles - low or short gears are 5.13, 4.56, 4.30, 4.11, etc. High or tall is 2.45, 2.71, 2.76, 2.94, etc.
Free advice and worth every penny... Factory trained Slinky rewinder.........
