... you s ... lay off the ....
The transmission inner gearing is way diff than the final drive rear-end ratio.
PLUS the resident Xpert here (Doc Diff) labels this whole deal as a 2.76 being a low-ratio BUT IS a high-speed gear. I will accept that ... but you just keep "hitting the pipe".
Well you can HITit by yurrself.
