Quote: I think you're the only one who understands the "reverse logic" on how a low number ratio is "short"
MY warped logic ?
Oh-tay then ... if you are 72 inches in length ...and your wife is 60 inches .... using YOUR logic ....
she is TALLER than you ...
Like I said doc. I understand what you're saying, and your twisted logic. Larger number means taller number. But my point was that you're the only person I know who thinks that way when it comes to gear ratios.
