Quote: Ever take one apart to see if those boosters could be repro'd and fit into a std TQ?
I imagine some of the tricks that went into the Comp Series design could be incorporated into the std TQ's, No?
I've taken many of them appart but haven't gone into any frankenstein experiments with the boosters, mainly because I haven't really found the need to. I suppose anything is possible if you played with them enough.
not sure what boosters are being talked about but i have read where you can cut out the outer ring of the booster on the 850 TQ making it about 1000 cfm's, and if you remove the choke plate and related shafts add another 60cfm's. BTW these TQ's are also popular with the big cube Buick guys.
