Wilwood brake problem....long #996806
05/21/11 05:55 PM
05/21/11 05:55 PM
Woodstock , Georgia
Mopar_racer_99 Offline OP
Woodstock , Georgia
Ok guys, Need to pick your brains. We have strange axles, 5/8 studs, 5 on 4.5 bolt circle, with 2.36 axle stand off. We used the wilwood brake kit, 140-0260-B . Using the mp green bearing with flange. Instructions tell you to press off the flange of bearing and use the wilwood plate, but my strange housing ends are 1.25 deep, but the bearing is only 1 inch allowing the axle to move back and forth. What is the deal????? or do I need to order the other backing plate and use the snap ring bearing? Also why does the rotor hat not locate off the the axle register?Hat is 1/4 inch bigger in dia. John 404-452-7737
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Wilwood brake problem....long [Re: Mopar_racer_99] #996807
05/21/11 06:04 PM
05/21/11 06:04 PM
Q
Quicktree Offline
Quicktree  Offline
Q
can you post some pics?
Re: Wilwood brake problem....long [Re: Mopar_racer_99] #996808
05/21/11 07:07 PM
05/21/11 07:07 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
You need to have the snap ring with the green bearing to do this swap.
home of the
Sox and Martin Hemi Duster
Re: Wilwood brake problem....long [Re: Mopar_racer_99] #996809
05/21/11 08:29 PM
05/21/11 08:29 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
I had the same issues with the rotor and had to get the center hole machined wider to fit the axle register.
I used my original flange plate and not the one in the kit. IIRC I had to remove the snap rings from the bearing and them put the wilwood plates and then put the ring back on.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: Wilwood brake problem....long [Re: Mopar_racer_99] #996810
05/21/11 09:49 PM
05/21/11 09:49 PM
AndyF Offline
AndyF  Offline
Wilwood makes generic kits so they aren't really designed to bolt on a Mopar. You have to do the finish work yourself to make it fit correctly.
If you want a bolt on kit you have to go to a vendor who has a true Mopar design. DoctorDiff on this board has a nice rear disc kit that fits and works on Mopar rear ends.
Re: Wilwood brake problem....long [Re: AndyF] #996811
05/21/11 10:55 PM
05/21/11 10:55 PM
Woodstock , Georgia
Woodstock , Georgia
If I make a spacer that fits between the bearing and the depth of the axle housing pocket. I am thinking that would fix the issue. Lucky they sell a 2 1/2 inch sch 40 and sch 80 pipe that is 2.875 od with a .203 and .276 wall. If I am off base in my thoughts tell me. John
Re: Wilwood brake problem....long [Re: Mopar_racer_99] #996812
05/21/11 11:06 PM
05/21/11 11:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know if I would make a spacer out of plastic
pipe... for a few bucks you can make it out of alum...
I'm just thinking of temp
Re: Wilwood brake problem....long [Re: MR_P_BODY] #996813
05/21/11 11:32 PM
05/21/11 11:32 PM
Woodstock , Georgia
Woodstock , Georgia
Oh I am talking steel sch pipe. I never would have thought about plastic pipe. The spiff happens seems to be running wild this year all on its own, I am not going to help it along. lol John
