Wilwood brake problem....long
#996806
05/21/11 05:55 PM
05/21/11 05:55 PM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
Ok guys, Need to pick your brains. We have strange axles, 5/8 studs, 5 on 4.5 bolt circle, with 2.36 axle stand off. We used the wilwood brake kit, 140-0260-B . Using the mp green bearing with flange. Instructions tell you to press off the flange of bearing and use the wilwood plate, but my strange housing ends are 1.25 deep, but the bearing is only 1 inch allowing the axle to move back and forth. What is the deal????? or do I need to order the other backing plate and use the snap ring bearing? Also why does the rotor hat not locate off the the axle register?Hat is 1/4 inch bigger in dia. John 404-452-7737
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Wilwood brake problem....long
[Re: Mopar_racer_99]
#996807
05/21/11 06:04 PM
05/21/11 06:04 PM
Quicktree
#996808
05/21/11 07:07 PM
05/21/11 07:07 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
You need to have the snap ring with the green bearing to do this swap.
home of the Sox and Martin Hemi Duster
#996809
05/21/11 08:29 PM
05/21/11 08:29 PM
Posts: 4,085 Indiana
W5Duster436
Indiana
I had the same issues with the rotor and had to get the center hole machined wider to fit the axle register.
I used my original flange plate and not the one in the kit. IIRC I had to remove the snap rings from the bearing and them put the wilwood plates and then put the ring back on.
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
[Re: AndyF]
#996811
05/21/11 10:55 PM
05/21/11 10:55 PM
Mopar_racer_99
Woodstock , Georgia
If I make a spacer that fits between the bearing and the depth of the axle housing pocket. I am thinking that would fix the issue. Lucky they sell a 2 1/2 inch sch 40 and sch 80 pipe that is 2.875 od with a .203 and .276 wall. If I am off base in my thoughts tell me. John
#996812
05/21/11 11:06 PM
05/21/11 11:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont know if I would make a spacer out of plastic pipe... for a few bucks you can make it out of alum... I'm just thinking of temp ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#996813
05/21/11 11:32 PM
05/21/11 11:32 PM
Mopar_racer_99
Woodstock , Georgia
Oh I am talking steel sch pipe. I never would have thought about plastic pipe. The spiff happens seems to be running wild this year all on its own, I am not going to help it along. lol John
