Rollout differences in slicks #990228
05/11/11 03:36 AM
05/11/11 03:36 AM
Redding,CA USA
440charger500 Offline OP
Redding,CA USA
So I just recieved my pheonix slicks one at a time from Summit and they are way different. The first one shows up and has a 90" rollout then a week later my second one shows up with a 88 3/4" rollout. I paid for them at the sametime not relizing they would ship from two different locations and send me tires that far apart, This Sucks.
Re: Rollout differences in slicks [Re: 440charger500] #990229
05/11/11 07:45 AM
05/11/11 07:45 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Call them and send them back,it sucks but it happened to me 3 different times.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: Rollout differences in slicks [Re: 440charger500] #990230
05/11/11 09:03 AM
05/11/11 09:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats why I dont buy slicks from them anymore... I
buy from Harlow tire
Re: Rollout differences in slicks [Re: MR_P_BODY] #990231
05/11/11 09:35 AM
05/11/11 09:35 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
i live close to pomona ca. when the winternationals come i always buy my slicks right off the manufacture trucks. the tires are as fresh as they come and perfectly matched since there there to support the racers. not sure if you have any big events your way. i started doing that since i had the same thing happen like you told.
Re: Rollout differences in slicks [Re: 440charger500] #990232
05/11/11 12:44 PM
05/11/11 12:44 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
When you buy at a national event they will mount and balance them (no extra charge)and measure the roll out making sure they are the same.
Re: Rollout differences in slicks [Re: hankcrank] #990233
05/11/11 07:00 PM
05/11/11 07:00 PM
Redding,CA USA
Redding,CA USA
Well I called Summit and they are sending me a tire thats a 1/4" different than my largest one. Thats close enough for me.
Re: Rollout differences in slicks [Re: 440charger500] #990234
05/11/11 07:36 PM
05/11/11 07:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You need to mention when you order that you want them the same OD, as in "matched set". With a spool, it matters to me.
Re: Rollout differences in slicks [Re: topside] #990235
05/11/11 07:43 PM
05/11/11 07:43 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I did just that when I ordered my new slicks from Summit last week. Both tires have exactly the same indicated rollout.
I learned the hard way after they sent a mismatched set the first time I bought from them.
Re: Rollout differences in slicks [Re: 440charger500] #990236
05/11/11 07:49 PM
05/11/11 07:49 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
I have a word of caution, the numbers chalked on the tires for rollout are not to be trusted. You must mount the tires put race ready air pressure in and measure the rollout with preferably a cloth tape measure to assure accuracy. Only then can you be sure of the rollout measurement. My experience is the number on the tire when you get it means next to nothing, I believe the distributors just put the same numbers on sets to sell in and effort to eliminate some customers from bitching about rollout differences (which does happen). I run Pheonix exclusively so I like the tire, it works the best, but you gotta check their rollout.
Re: Rollout differences in slicks [Re: 540dust] #990237
05/11/11 08:02 PM
05/11/11 08:02 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Rollout differences in slicks [Re: 540dust] #990238
05/12/11 03:43 AM
05/12/11 03:43 AM
I bougt a used new set from a member on here last year, tey had not been mounted and where marked the same size on both tires. I had them mounted and then check the circumference at 12 lbs, not within 3/4 inch I inflated the small one for several days to 15 lbs at first and then to 20 lbs and finally to 30 lbs to get them within 1/8 inch of each other. I let the little one  down to 12 lbs again and it was still out close to 1/2 inch smaller so I ended up running it at 13 lbs. amd 10 lbs in the big one to get them to 1/8 inch of each other
Re: Rollout differences in slicks [Re: Cab_Burge] #990239
05/12/11 07:29 AM
05/12/11 07:29 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
It is not that uncommon to have tires that are different rollout. The deal is fix it before ever running the tire. 30psi in the sun. Stretch a little at a time checking the tires at equal pressure. Once it is right. Mount the tires on the car and do a burnout to heat cycle the tires. I would not suggest ever running a set of tires with unequeal rollout, but have always had good success stretching the short tire.
Leon
Re: Rollout differences in slicks [Re: MR_P_BODY] #990240
05/12/11 10:02 AM
05/12/11 10:02 AM
NC
440Jim Offline
440Jim  Offline
NC
Harlow is #1 and I have recieved good service from Coker Tire also (dragtraceires.com)
They went to the shelfs and selected the rollout I wanted, and of course a matched set.
As mentioned, check it yourself, and I have made 1/2" corrections (air pressure stretch) to "fine" match them. And that has to be done before doing the first burnout.
