Re: 70 4 speed
[Re: waspnest69]
#978015
04/22/11 12:40 PM
04/22/11 12:40 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
The shift rods are the same, the pistol grip is different.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
Re: 70 4 speed
[Re: waspnest69]
#978016
04/22/11 12:40 PM
04/22/11 12:40 PM
Posts: 15,996 RI Deep in the rust belt
chargervert
I believe everything is the same console to non console pistol grip shifters,except the shifter handle itself. The console shifter handle has about a 4 inch bend to divert the handle through the center of the console,and then it's bent back towards the driver. The non console shifter handle has a half inch offset at the bottom of the handle,and is straight the rest of it's length. The shifter box is set up to shorten the shifter throw,to compensate the long shifter handle.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
Re: 70 4 speed
[Re: waspnest69]
#978020
04/23/11 10:20 AM
04/23/11 10:20 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
My trans keeps jamming between gears and not sure if its my shift rods causing it.
First thing I would do is be sure the linkage adjustments "are" correct.
