70 4 speed #978013
04/22/11 12:32 PM
04/22/11 12:32 PM
searcy ark
W
waspnest69 Offline OP
W
searcy ark
Are 70 counsel and non consel shift rods different for a pistol grip?
Re: 70 4 speed [Re: waspnest69] #978014
04/22/11 12:39 PM
04/22/11 12:39 PM
searcy ark
W
W
searcy ark
My trans keeps jamming between gears and not sure if its my shift rods causing it.
Re: 70 4 speed [Re: waspnest69] #978015
04/22/11 12:40 PM
04/22/11 12:40 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
The shift rods are the same, the pistol grip is different.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: 70 4 speed [Re: waspnest69] #978016
04/22/11 12:40 PM
04/22/11 12:40 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
I believe everything is the same console to non console pistol grip shifters,except the shifter handle itself. The console shifter handle has about a 4 inch bend to divert the handle through the center of the console,and then it's bent back towards the driver. The non console shifter handle has a half inch offset at the bottom of the handle,and is straight the rest of it's length. The shifter box is set up to shorten the shifter throw,to compensate the long shifter handle.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: 70 4 speed [Re: Mick70RR] #978017
04/22/11 12:41 PM
04/22/11 12:41 PM
searcy ark
W
W
searcy ark
What do I need to make it right? sometimes it shifts perfect then without warning.....Its stuck.
Re: 70 4 speed [Re: waspnest69] #978018
04/22/11 01:07 PM
04/22/11 01:07 PM
searcy ark
W
W
searcy ark
Maybe trade it for a 69 camaro?
Re: 70 4 speed [Re: waspnest69] #978019
04/23/11 09:59 AM
04/23/11 09:59 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
What body type are we talking about here?
Re: 70 4 speed [Re: waspnest69] #978020
04/23/11 10:20 AM
04/23/11 10:20 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
First thing I would do is be sure the linkage adjustments "are" correct.
Re: 70 4 speed [Re: 62maxwgn] #978021
04/23/11 10:25 AM
04/23/11 10:25 AM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
Worn out bushings or incorrect adjustment will cause problems.
Re: 70 4 speed [Re: Mick70RR] #978022
04/23/11 10:30 AM
04/23/11 10:30 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
AS long as they are shift rods for a 1970 B- body pistol grip !
regular Hurst stuff is different , linkage from a basic Hurst will not work .
1969 Dodge Charger 1969 Dodge Superbee
Re: 70 4 speed [Re: cjs69mope] #978023
04/24/11 07:21 AM
04/24/11 07:21 AM
searcy ark
W
W
searcy ark
Thanks for all the help.Its a 69 Bee with a 70 pistol grip...Found out only 70 shift rods will work....So going to rebuild the shifter and put in the correct rods.Ive always had to have a 4 speed in my muscle cars but.....Going to go with an automatic in my 70 Bee....Im getting to old to push in the clutch anyway.
Re: 70 4 speed [Re: waspnest69] #978024
04/24/11 07:26 AM
04/24/11 07:26 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
There's a bunch of information on stuck shifters/transmissions and shifter adjustments here:
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=QuestionAnswer&Number=6483894
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: 70 4 speed [Re: Evil Monkey] #978025
04/24/11 07:39 AM
04/24/11 07:39 AM
searcy ark
W
W
searcy ark
Thank You so much...Thats a great help.This was my first mopar project which took 12 years..2 divorces hunting parts because the car was so incomplete.Then had a bunch of stuff stolen..and also mixed up in piles...But...finally took her for a ride and LOVED IT...cant wait to get the front end alligned though...
