Six pack carb mount bolts #97667
07/31/08 02:13 PM
07/31/08 02:13 PM
Id
mopeman Offline OP
mopeman  Offline OP
Id
Well I got my MP six pack install kit and there are no mount bolts for the carbs !!!!! Do they expect you to glue the carbs on!!! Alright, enough of my whining. Can I still get the bolts from the dealer (need P/N's) or will I have to go to one of the resto suppliers? I also have a good hardware store close by and I can get bolts there if I know the proper size, just don't want it to look backwoods or rigged up.
Mopar or no car
MoPar=Massivly Over Powered And Respected!
'93 W250 Ram
'68 Charger
'67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: Six pack carb mount bolts [Re: mopeman] #97668
07/31/08 04:17 PM
07/31/08 04:17 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
they should be studs with nuts (1/4-20)
Re: Six pack carb mount bolts [Re: macmic87] #97669
07/31/08 04:22 PM
07/31/08 04:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Wrong!!!
They are 5/16-18 bolts they are black phophate with a distinctive logo on the head I believe they should be 1.25 long & either Bill @ A&M High Tech Automotive or Tom @ R/T Specialties will stock them...
Re: Six pack carb mount bolts [Re: 1_WILD_RT] #97670
07/31/08 08:51 PM
07/31/08 08:51 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Correct...And no washers either...If originality is'nt a factor then the local hardware store will have what you need...But as stated the correct pieces will have a specific "H" headmarking...
Re: Six pack carb mount bolts [Re: screamindriver] #97671
07/31/08 09:25 PM
07/31/08 09:25 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Aren't they also used on non-6 pack applications, such as 2 bl small blacks of the era??
Careful, your character's showing!
Re: Six pack carb mount bolts [Re: mopar346] #97672
07/31/08 09:45 PM
07/31/08 09:45 PM
Harrisburg, Pa.
Harrisburg, Pa.
Yes, actually there were many bolts around the engine that had that peticular marking...Headbolts,dist.hold-down,etc...
Re: Six pack carb mount bolts [Re: screamindriver] #97673
07/31/08 10:27 PM
07/31/08 10:27 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Head markings are reference to the Highland bolt co. No longer avail from the dealership, but it's obviously avail thru any hardware store if your just after something that works with no regards to originality
5/16" - 18 x 1.25" used from 1968 thru late 1970 or early 1971 on about every V8 , although some 2 bbls used both bolts + studs and nuts combined
Re: Six pack carb mount bolts [Re: mopeman] #97674
08/01/08 09:08 PM
08/01/08 09:08 PM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
If your looking for something close to you that you can pick up fairly quickly, try going to your local Advance Auto parts or Autozone. Ask about the Mr Gasket Carburetor stud kit. It has 4 studs, 4 washers, and 4 nuts in each package. Kit number should be #60. It's not original, but works great. If you are just looking at getting it running and tuning it with the idea of maybe taking it off and on a few times, you might want to go with bolts till you get everything sorted out. The nuts and washers tend to fall out of reach of your fingers and can be a pain when you are working on a hot engine.
A True Hybrid: Burns Gas AND Rubber!
