overspray removal #967437
04/05/11 11:48 PM
04/05/11 11:48 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..i have a small amount of over spray on my rear window trim ('70 Duster)
what the best way to remove it..i think it's stainless and will take the trim off first.
will a product like paint stripper harm stainless steel?
Re: overspray removal [Re: can.al] #967438
04/05/11 11:51 PM
04/05/11 11:51 PM
Saskatchewan, Canada
barracudabob Offline
Try a clay bar. I've done several vehicles that had overspray. It worked well, but was a lot of effort(complete vehicle).
Re: overspray removal [Re: can.al] #967439
04/05/11 11:56 PM
04/05/11 11:56 PM
MD, Northern VA
Z
zrwhat Offline
zrwhat  Offline
Z
MD, Northern VA
And old painter's trick is using bronze wool on glass and trim to remove overspray, the bronzewool is very soft and will not scratch glass or chrome, I keep some around just for that reason.
Best place to find it is in a marine supply store or boat supply store, go with the finest grade you can, triple 0 or quad 0000 works best,
Good luck
Re: overspray removal [Re: can.al] #967440
04/06/11 12:25 AM
04/06/11 12:25 AM
wisconsin united states
K
keith airgrabber Offline
Right in the Nutz!!!
K
laquer thinner is what you need. Or steel wool fine.
Re: overspray removal [Re: can.al] #967441
04/06/11 01:13 AM
04/06/11 01:13 AM
Jacksonville Florida
elitecustombody Offline
Lacquer thinner
Re: overspray removal [Re: elitecustombody] #967442
04/06/11 11:15 AM
04/06/11 11:15 AM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
Try WD40 on a rag.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
