..i have a small amount of over spray on my rear window trim ('70 Duster)
what the best way to remove it..i think it's stainless and will take the trim off first.
will a product like paint stripper harm stainless steel?
And old painter's trick is using bronze wool on glass and trim to remove overspray, the bronzewool is very soft and will not scratch glass or chrome, I keep some around just for that reason.
Best place to find it is in a marine supply store or boat supply store, go with the finest grade you can, triple 0 or quad 0000 works best,
Good luck
