Max lift on stock 906 heads? #965923
04/04/11 05:26 PM
04/04/11 05:26 PM
Up in the North and Far Away
AutoEngineer Offline OP
What is the max cam lift on stock 906 heads with stock valves and stamped steel rockers?
Re: Max lift on stock 906 heads? [Re: AutoEngineer] #965924
04/04/11 06:02 PM
04/04/11 06:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Have the valve guides been trimmed or as delivered from mopar ?
Re: Max lift on stock 906 heads? [Re: JohnRR] #965925
04/04/11 06:25 PM
04/04/11 06:25 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I ran a voodoo with 533 and worked great changed it to a voodoo with like 550 and it wouldnt rev past 6200 rpm. Could have been the springs but I assumed I had some interference with the stock 906 heads.
67' charger 499 RB 10.57 at 127
Re: Max lift on stock 906 heads? [Re: AutoEngineer] #965926
04/04/11 06:35 PM
04/04/11 06:35 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
500-510 range is safe
Snap your neck, mega G-force launch, is all I want!
Re: Max lift on stock 906 heads? [Re: BDS871Cuda] #965927
04/04/11 11:14 PM
04/04/11 11:14 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Just measure it, why speculate?
Re: Max lift on stock 906 heads? [Re: scatpacktom] #965928
04/05/11 10:45 AM
04/05/11 10:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That would only make sense , but I think his more important question is how much lift can stamped steel rockers handle ?
Re: Max lift on stock 906 heads? [Re: AutoEngineer] #965929
04/06/11 12:08 AM
04/06/11 12:08 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
I run a Mopar 533 hyd with bone stock 346 head's,rocker and pushrods,in my 12.50 engine.
Re: Max lift on stock 906 heads? [Re: JohnRR] #965930
04/06/11 03:09 AM
04/06/11 03:09 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I've ran a .560 lift with stock rockers and it was together for many years. But then the heads were 915's
Re: Max lift on stock 906 heads? [Re: scatpacktom] #965931
04/06/11 01:40 PM
04/06/11 01:40 PM
Sorry, but I was not in my garage, when wrote that question and my garage is over 35 miles from my office, and I needed a honest answer because from Hughes Engines they said maximum lift with stock guide height is 0.450". More lift would require shortening the valve guides. I thought it's a little bit low, because I have even earlier used cams up to 0.507 without shortening guides.
Re: Max lift on stock 906 heads? [Re: pro6pakRR] #965932
04/06/11 03:58 PM
04/06/11 03:58 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Stock on top 346 heads, 0.518 lift with room to spare.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
