Re: Dyno Results for My 6.1 Hemi
[Re: Dartin]
#965373
04/04/11 02:23 PM
04/04/11 02:23 PM
Posts: 387 Almont, MI.
gdemon
Almont, MI.
Those are some great numbers. Cant wait to hear it run.
Jerry
69 Barracuda
70 Cuda
70 Cuda
70 Cuda Conv.
70 T/A Challenger
70 Sport Fury GT
71 Demon 5.7 Hemi
72 Demon
[Re: MuscleMike]
#965376
04/04/11 06:02 PM
04/04/11 06:02 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
That is nice I am really likin the Gen 3 hemi!
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: MuscleMike]
#965377
04/04/11 06:03 PM
04/04/11 06:03 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Mike, that thing is really going to push his car well. Thanks for doing the very first dyno test with our FireCore coil packs. I feel that these will be our biggest breakthrough since the developing our 8.5 wire. Thank you.
We only got the stock dyno results sheet in the fax. Thanks. Are you able to print out the A/F, EGT and O2? Thanks
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#965378
04/04/11 06:25 PM
04/04/11 06:25 PM
Posts: 232 Lansing, MI
MuscleMike
Lansing, MI
Hey Rick, sorry I forgot to mention your coil packs. Steve and I had agreed that we had gotten what we were gonna get out of the engine. Spark plugs had the mark in the middle of the bend, O2's looked good, ran with and with out the vacuum pump and it made 3 or 4 pulls between 554-556 HP.
I was skeptical to say the least that to coil packs would make a difference. I figured in a high compression or a boosted application it would matter but a 10:1 pump gas combo i figured the stock coils would be fine. It took us about 4 minutes to swap out the Firecore Coils for the stock ones and INSTANTLY lost 5 HP and 6 ft/lbs. A second pull verified that the Firecore Coilpacks definitely made more power. I would use the again in second, on ANY Gen III project!
Mike @MM
[Re: MuscleMike]
#965379
04/04/11 06:56 PM
04/04/11 06:56 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
Congrats, very impressive. I think it is great someone has decided to put this technology to work in a different build...
Is the intake working as well as if it was an EFI engine. Since the drag paks were design for EFI, I was just curious if that effects any hp or torque since the intake is now "wet" for the lack of a better word.
I dont know, so I am asking input on if there would be anymore power (not necessarily peak) if converted to efi???
Anyone have any hard data??? IE? Dyno sheets?
thanks jm
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: STEFF]
#965386
04/05/11 07:56 PM
04/05/11 07:56 PM
I dyno’d my 6.1 Hemi yesterday at Muscle Motors. All went well & I’m pleased with the results. I’ll post some pics of the dyno sheets, once I can darken up the copies I have as they washout when I take pics of them.
Motor Details: Stock Short Block, Modern Cylinder Head ported 6.1 Heads, 358/240cfm @ .650 lift, Stock 2.08/1.58 Hollow Stem Valves, PAC Springs & related parts, Stock Rockers, Trend Pushrods, 5/16 x .080 wall, Performance Werks Racing Custom Hydraulic Roller to work with stock piston (no valve reliefs): 224/228 @ .050, .620/.640 lift , 112CL +2 , Drag Pack Intake, Proform HP950 Carb, Milodon Pan & Windage Tray, Firecore Prototype Coil Packs, 1 3/4 primary x 30” long dyno headers, ATI Drag Pack Damper, Meziere Remote Water Pump.
Dyno pulls were from 4500 to 6500 rpms.
Torque curve is very nice, starting at 472 ft. lbs. at 4540 rpm, peaking at 487 ft. lbs at 5258 rpm, then tapering off to 450.5 at 6454 rpm
Horse Power started at 408.1hp @ 4540 rpm & steadily climbing to a peak of 556.5 hp @ 6441 rpm.
I know dyno’s are what they are & the proof is in the MPH at the track. But, I’m still very pleased! I’ve got plenty of data now for a base line for a converter, fuel & timing.
Big Thanx to Mike Ware for the dyno & help…… Rick Gorski & Firecore for the Coil Packs. They DO make Power!!.... Andy at PWR for the Cam & to Jeff at Modern for the Awesome Port Work!!
It’s going to be a FUN Summer!!!!
Awesome results. Very Cool. How long did it take to build?
#965387
04/05/11 10:08 PM
04/05/11 10:08 PM
Posts: 3,872 Smyrna, South Carolina
STEFF
Not long at all. I started a low mileage, running motor & made the changes described in my first post.
Thanx Again Everyone for the compliments!!
[Re: Bubba]
#965388
04/05/11 10:52 PM
04/05/11 10:52 PM
Posts: 936 Deland, Florida
biff426
Deland, Florida
WOW Great Numbers SteveO... Anyone wanna buy a World Block and Callies Crank?
YEP
[Re: MikeCompTA 57]
#965390
04/06/11 07:37 AM
04/06/11 07:37 AM
STEFF
Are these numbers with the serpentine belt and all the accessories?
There are no accessories other than an alternator & it was not on the motor when dynoing. I did try a vaccuum pump on the motor.
[Re: STEFF]
#965392
04/06/11 10:33 AM
04/06/11 10:33 AM
Posts: 3,363 DTW
drmopar
DTW
Awesome Steve, I look forward to seeing my old road runner on the road with that potent driveline!
-------------------- RM27H9G 4 speed F8/tan guts RS27L9G auto B5/black guts WM23H9G auto F5/green guts 2021 Challenger 392 Indigo/black guts 2019 Charger Daytona R/T F8 on black 2018 Ram Sport Hemi 4x4
