Page 2 of 3 1 2 3
Re: Dyno Results for My 6.1 Hemi [Re: Dartin] #965373
04/04/11 02:23 PM
04/04/11 02:23 PM
Almont, MI.
gdemon Offline
gdemon  Offline
Almont, MI.
Those are some great numbers. Cant wait to hear it run.
Jerry
69 Barracuda 70 Cuda 70 Cuda 70 Cuda Conv. 70 T/A Challenger 70 Sport Fury GT 71 Demon 5.7 Hemi 72 Demon
Re: Dyno Results for My 6.1 Hemi [Re: gdemon] #965374
04/04/11 04:59 PM
04/04/11 04:59 PM
Utah
topbrent Offline
topbrent  Offline
Utah
What power difference do you think there would be between the tall Mopar Drag Pack intake you are currently using, and a lower XV style intake?
Re: Dyno Results for My 6.1 Hemi [Re: STEFF] #965375
04/04/11 05:44 PM
04/04/11 05:44 PM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
Can't argue with results. 556 HP and 486 toque out of a little ole 370" engine is stout. Honestly when it idles down to 750 rpm you can't even tell there is a "cam in it". Because of the stock piston design you can't put a lot of duration in it or even open the intake valve earlier to lower your peak torque RPM. I do believe the MP intake is worth power over the XV but the XV is 1)available and 2)will not require a hood scoop.
Just goes to show what a good flowing set of head will do for ya. Going from 7" of vacuum to no vacuum yeilded ZERO difference in power (with the stock ring package that Steff ran)
The flat/broad torque curve is really impressive and will really pull like a freight train in high gear.
Re: Dyno Results for My 6.1 Hemi [Re: MuscleMike] #965376
04/04/11 06:02 PM
04/04/11 06:02 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
That is nice I am really likin the Gen 3 hemi!
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Dyno Results for My 6.1 Hemi [Re: MuscleMike] #965377
04/04/11 06:03 PM
04/04/11 06:03 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Mike, that thing is really going to push his car well. Thanks for doing the very first dyno test with our FireCore coil packs. I feel that these will be our biggest breakthrough since the developing our 8.5 wire. Thank you.
We only got the stock dyno results sheet in the fax. Thanks. Are you able to print out the A/F, EGT and O2? Thanks
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Dyno Results for My 6.1 Hemi [Re: sunroofgtx] #965378
04/04/11 06:25 PM
04/04/11 06:25 PM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
Hey Rick, sorry I forgot to mention your coil packs. Steve and I had agreed that we had gotten what we were gonna get out of the engine. Spark plugs had the mark in the middle of the bend, O2's looked good, ran with and with out the vacuum pump and it made 3 or 4 pulls between 554-556 HP.
I was skeptical to say the least that to coil packs would make a difference. I figured in a high compression or a boosted application it would matter but a 10:1 pump gas combo i figured the stock coils would be fine. It took us about 4 minutes to swap out the Firecore Coils for the stock ones and INSTANTLY lost 5 HP and 6 ft/lbs. A second pull verified that the Firecore Coilpacks definitely made more power. I would use the again in second, on ANY Gen III project!
Mike @MM
Re: Dyno Results for My 6.1 Hemi [Re: MuscleMike] #965379
04/04/11 06:56 PM
04/04/11 06:56 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Congrats, very impressive. I think it is great someone has decided to put this technology to work in a different build...
Is the intake working as well as if it was an EFI engine. Since the drag paks were design for EFI, I was just curious if that effects any hp or torque since the intake is now "wet" for the lack of a better word.
I dont know, so I am asking input on if there would be anymore power (not necessarily peak) if converted to efi???
Anyone have any hard data??? IE? Dyno sheets?
thanks jm
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Dyno Results for My 6.1 Hemi [Re: wldtm] #965380
04/04/11 08:38 PM
04/04/11 08:38 PM
Akron, Ohio
ProSport Online content
ProSport  Online Content
Akron, Ohio
Nice numbers Steff! Gonna be a fun car!
Re: Dyno Results for My 6.1 Hemi [Re: wldtm] #965381
04/04/11 08:46 PM
04/04/11 08:46 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
thanks jm
You can rest assured that EFI will outrun a carb in basically any application if properly tuned. There is so much that you can do with a laptop as far as fuel curves are concerned that it is apples to oranges comparison.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Dyno Results for My 6.1 Hemi [Re: topbrent] #965382
04/04/11 11:15 PM
04/04/11 11:15 PM
MN
hemidup Offline
hemidup  Offline
MN
Our dyno sheet's using a stock 5.7 truck intake vs 6.1 SRT8 intake vs the 5.7 XV intake. The engine was a 6.1 based 418 stroker using our 5.7 cnc heads. Even with matched ports, the XV lacked in both hp and tq. The port matched 5.7 truck intake and the mismatched 6.1 SRT8 intake where pretty much neck n neck. All the above intakes were tested using the same adjusted fuel trims.
Jerry Williams.
Re: Dyno Results for My 6.1 Hemi [Re: hemidup] #965383
04/04/11 11:37 PM
04/04/11 11:37 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
that makes me wonder how the edelborck with longer runner duel plane would do. that intake looks like a big loss across the whole chart
Very Nice Steff
Re: Dyno Results for My 6.1 Hemi [Re: hemidup] #965384
04/04/11 11:37 PM
04/04/11 11:37 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Way to go Steff ! and thanks again
Re: Dyno Results for My 6.1 Hemi [Re: 10secGTX] #965385
04/05/11 03:33 PM
04/05/11 03:33 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
WOW Great Numbers SteveO... Anyone wanna buy a World Block and Callies Crank?
Re: Dyno Results for My 6.1 Hemi [Re: STEFF] #965386
04/05/11 07:56 PM
04/05/11 07:56 PM
I dyno’d my 6.1 Hemi yesterday at Muscle Motors. All went well & I’m pleased with the results. I’ll post some pics of the dyno sheets, once I can darken up the copies I have as they washout when I take pics of them.
Motor Details: Stock Short Block, Modern Cylinder Head ported 6.1 Heads, 358/240cfm @ .650 lift, Stock 2.08/1.58 Hollow Stem Valves, PAC Springs & related parts, Stock Rockers, Trend Pushrods, 5/16 x .080 wall, Performance Werks Racing Custom Hydraulic Roller to work with stock piston (no valve reliefs): 224/228 @ .050, .620/.640 lift , 112CL +2 , Drag Pack Intake, Proform HP950 Carb, Milodon Pan & Windage Tray, Firecore Prototype Coil Packs, 1 3/4 primary x 30” long dyno headers, ATI Drag Pack Damper, Meziere Remote Water Pump.
Dyno pulls were from 4500 to 6500 rpms.
Torque curve is very nice, starting at 472 ft. lbs. at 4540 rpm, peaking at 487 ft. lbs at 5258 rpm, then tapering off to 450.5 at 6454 rpm
Horse Power started at 408.1hp @ 4540 rpm & steadily climbing to a peak of 556.5 hp @ 6441 rpm.
I know dyno’s are what they are & the proof is in the MPH at the track. But, I’m still very pleased! I’ve got plenty of data now for a base line for a converter, fuel & timing.
Big Thanx to Mike Ware for the dyno & help…… Rick Gorski & Firecore for the Coil Packs. They DO make Power!!.... Andy at PWR for the Cam & to Jeff at Modern for the Awesome Port Work!!
It’s going to be a FUN Summer!!!!
Awesome results. Very Cool. How long did it take to build?
Re: Dyno Results for My 6.1 Hemi #965387
04/05/11 10:08 PM
04/05/11 10:08 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Not long at all. I started a low mileage, running motor & made the changes described in my first post.
Thanx Again Everyone for the compliments!!
Re: Dyno Results for My 6.1 Hemi [Re: Bubba] #965388
04/05/11 10:52 PM
04/05/11 10:52 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
YEP
Re: Dyno Results for My 6.1 Hemi [Re: MuscleMike] #965389
04/06/11 05:37 AM
04/06/11 05:37 AM
Loveland, Ohio
MikeCompTA 57 Offline
Loveland, Ohio
Are these numbers with the serpentine belt and all the accessories?
Re: Dyno Results for My 6.1 Hemi [Re: MikeCompTA 57] #965390
04/06/11 07:37 AM
04/06/11 07:37 AM
STEFF Offline OP
STEFF  Offline OP
There are no accessories other than an alternator & it was not on the motor when dynoing. I did try a vaccuum pump on the motor.
Re: Dyno Results for My 6.1 Hemi [Re: STEFF] #965391
04/06/11 10:32 AM
04/06/11 10:32 AM
MN
hemidup Offline
hemidup  Offline
MN
Any gains shown with the vaccuum pump?
Jerry Williams.
Re: Dyno Results for My 6.1 Hemi [Re: STEFF] #965392
04/06/11 10:33 AM
04/06/11 10:33 AM
DTW
drmopar Offline
drmopar  Offline
DTW
Awesome Steve, I look forward to seeing my old road runner on the road with that potent driveline!
RM27H9G 4 speed F8/tan guts
RS27L9G auto B5/black guts
WM23H9G auto F5/green guts
2021 Challenger 392 Indigo/black guts
2019 Charger Daytona R/T F8 on black
2018 Ram Sport Hemi 4x4
Page 2 of 3 1 2 3
