'68 - 70 B body vent window anti rattle spacer? #955610
03/21/11 04:16 PM
03/21/11 04:16 PM
Kelowna, B.C. Canada
DPelletier Offline OP
Anybody know where to get (or even what they look like) the "anti rattle spacers" that go over the pin inside the bottom of the door to hold/locate the vent window frame?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: '68 - 70 B body vent window anti rattle spacer? [Re: DPelletier] #955611
03/21/11 06:05 PM
03/21/11 06:05 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Have mine apart right now and I am not sure what part you are referring to. Do you have any pictures or diagrams showing this part in an assembly or by itself?
Re: '68 - 70 B body vent window anti rattle spacer? [Re: 70mopes] #955612
03/21/11 10:18 PM
03/21/11 10:18 PM
waukon iowa
1hot68 Offline
1hot68  Offline
waukon iowa
Its just a pice of foam to keep it from rattling. not any clip or whatever,just a chunk kinda wedged on when its slid down onto it.
Re: '68 - 70 B body vent window anti rattle spacer? [Re: 1hot68] #955613
03/21/11 11:36 PM
03/21/11 11:36 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Oh.... Was thinking of something else. This is what you are referring to. This is a shot of an original installation.
Re: '68 - 70 B body vent window anti rattle spacer? [Re: 70mopes] #955614
03/22/11 09:56 AM
03/22/11 09:56 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
that pic is the guy,i used heavy shipping foam cut to size ,wasn't going to pay 20+
Re: '68 - 70 B body vent window anti rattle spacer? [Re: DPelletier] #955615
03/22/11 01:02 PM
03/22/11 01:02 PM
Thanks guys; I have 4 doors and none of them have anything on that pin. The parts manual calls up a "anti rattle spacer" or something like that, but I had never seen one.
My guy that's helping me insists that there should be a bushing or something that can be supply upwards pressure to the vent frame to keep in in place as the other two bolts appear inadequate to the task, but I told him I had my doubts and that if there was a bushing, it wouldn't have been called an "anti rattle spacer", it would have been called a bushing, spring or spacer.
sounds like that pin just provides a locate and doesn't push up on the vent frame at all.
Re: '68 - 70 B body vent window anti rattle spacer? [Re: DPelletier] #955616
03/22/11 11:33 PM
03/22/11 11:33 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I have found that the pin is just for glass tilt adjustment for a tighter fit to the door frame .
I have found many of cars with them broke off the frame and window worked ok .
the cars i have had three b bodys all had them broken off and sitting at the bottom of the door and when i restore them i welded the part back on to the window vent channel run never used any type of bushing and never heard or had one rattle yett .
not saying it wont just do see it to be much of a problem to worrie about , my fuel pump is louder than most rice burners out there HA HA.
1969 Dodge Charger 1969 Dodge Superbee
Re: '68 - 70 B body vent window anti rattle spacer? [Re: cjs69mope] #955617
03/23/11 12:21 PM
03/23/11 12:21 PM
That's what my buddy is saying; that the pin pushes up to tilt the vent frame for a tighter fit to the door frame, but it can't do that unless there is something to give it upwards pressure right? without any sort of bushing, the vent frame is free to float on the pin with no upwards pressure.
I'm convinced that there was no such bushing, but without one, you are relying on the two upper bolts to hold the vent frame in position, correct?
Re: '68 - 70 B body vent window anti rattle spacer? [Re: 70mopes] #955618
03/23/11 02:48 PM
03/23/11 02:48 PM
CANADA
Desmond Offline
Desmond  Offline
CANADA
That is so lame.
Re: '68 - 70 B body vent window anti rattle spacer? [Re: DPelletier] #955619
03/24/11 12:41 AM
03/24/11 12:41 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I just looked in my old door that come off my GTX.
That pin does NOT put upwards pressure on the channel.....it adjusts in and out in a slot in the bottom of the door to keep the lower portion of the track in the proper relation to the top section that bolts to the door.Without that pin holding the channel it could "wander" around when the glass is rolled down. The "sponge" just keeps it snug in the channel bracket.
It does help with the alignment of the whole vent channel. but only in and out.
Re: '68 - 70 B body vent window anti rattle spacer? [Re: DPelletier] #955620
03/24/11 01:30 AM
03/24/11 01:30 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
There are 3 bolts that hold the vent frame in place.... the 2 9/16s bolts under the plastic caps and the allen head bolt under the tiny plug. The white foam insert is the correct way the factory did them.
Re: '68 - 70 B body vent window anti rattle spacer? [Re: superwrench] #955621
03/24/11 01:47 AM
03/24/11 01:47 AM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
Dave There should be no upward pressure. The stud is tightened in a bracket from the bottom of the door and the hex on the top of the stud. And the vent window end floats on the stud. This will give you in and out adjustment of the vent frame. A little moves it a bunch on the top of the vent window. I had to actually re-adjust mine when I put my roof rail weatherstrip in. And the vent window is attached in the front and by the allen head screw in the arch of the window frame area. As far as the seal is concerned it is a anti-rattle seal. I used a thick strip of foam packing that I cut from extra shipping packing (I had some from all the over priced parts that were shipped to me ) You could probably get some from any place that sells packaging supplies. Is this for your Bee I thought your windows were all in?
Scott
70 Coronet RT 440+6
64 Dodge 330 - Future Hemi Clone
17 Challenger Hellcat - Green Go Driver
86 Buick T-Type Turbo V-6
Re: '68 - 70 B body vent window anti rattle spacer? [Re: hemi70se] #955622
03/24/11 01:50 AM
03/24/11 01:50 AM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
You beat me darn it
Scott
70 Coronet RT 440+6
Re: '68 - 70 B body vent window anti rattle spacer? [Re: SixPackRT] #955623
03/24/11 01:40 PM
03/24/11 01:40 PM
[quote Is this for your Bee I thought your windows were all in?
Scott
Thanks guys. Yeah, it's for the Bee and all the windows are in with the exception of the 1/4 windows. I thought all I needed to do was add a couple missing rods to the door latches, but it turned into a complete teardown and reworking of all the door components!
Re: '68 - 70 B body vent window anti rattle spacer? [Re: DPelletier] #955624
03/24/11 02:11 PM
03/24/11 02:11 PM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
Been there!
Scott
70 Coronet RT 440+6
Re: '68 - 70 B body vent window anti rattle spacer? [Re: SixPackRT] #955625
03/24/11 02:29 PM
03/24/11 02:29 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You beat me darn it
Scott
And that is your answer, wasn't sure if you picked it up earlier so I thought I'd highlight it....
